Need to know which SWM LNB is compatible with H25-100 receiver | SatelliteGuys.US
Todd Sabo
Hi there,
I'm new to the forum and have a question about the which SWM lnb I need to get for my H25-100 boxes. This is for a tailgating system, running two boxes and I already have a Slimline dish with tripod. The problem is that I upgraded all my standard boxes which used to work with the SL5K4NR0-02 LNB to the HD H25-100. I was unaware that the H25 needed a SWM system and was hosed during the first game.
I want to upgrade and don't want to spend a ton of cash. I've read that the SWM 3 should work fine, needs a power inverter, 4 way splitter and is easier to point than the others. Is this true? If so, I found a complete system on ebay for only $25.
Any insight would be appreciated.
Todd
:welcome to Satelliteguys!
You have answered all of your own questions! :) You don't need us! Just a minor correction, it's called a power inserter. Make sure you get the 21 volt model.
Stone Cold
New customer - AM21 ordering issue
