Hi, Does anyone know how to reprogram the data for individual channels on a Geosatpro HDVR3500 receiver? One channel moved to a new frequency/transponder on the same satellite.
I've never used that receiver but would think the simplest way to update a channel that has changed frequencies is to just do a manual scan for the channel on the new frequency it is on. If there are no channels left on it's old frequency just delete that transponder or keep it if there are.
Hi, Thanks for your advice. Unfortunately the information in the user manual provided with the receiver does not match what I am seeing in the on screen display. The manual explains how to do a 1 channel search however the method does not appear on the screen.
