Netflix on 4k Joey | SatelliteGuys.US
Netflix on 4k Joey
PaulF72
2
Columbia, SC
Is Netflix available on a 4k Joey? I just replaced a Joey 2 with a 4k Joey, when I try to start Neflix service a popup windows reads "Netflix will be available soon. Please check back later." Will Netflix populate to the 4k Joey after a period of time or is Netflix not active on the 4k Joey?
Netflix is not available on the 4k Joey and like the PIP that was supposed to be on the 4k Joey neither will likely ever be.
I figured as much, I had trouble with Netflix after an hour or so freezing up on the Joey2 so I usually watch it thru the Tv built in app.
Thanks for reply.
Hopper 3 Stops in the middle of playback
Can you use multiple OTA USB adapters on a HWS?
