Network media player wanted | SatelliteGuys.US
techno935
1,048
Pompano Beach, FL
I've been checking around Ebay for something decent and I've seen a lot of Chinese units. I'm a little weary about buying from China if you know what I mean.
That said..I'm seeking a network media player with:
(1) Full 1080i
(2) Component out (Y,Pb,Pr)
(3) Wired networking LAN port (with option to go wireless)
Just wondering if anyone has tinkered with such a device that fits the criteria and doesn't suck so bad.
I don't want a Chinese unit that will fail in 2 months due to bad capacitors or something that isn't full HD
Any input is appreciated...thanks!
I think most of the CE electronics (or at least components that go into it) are manufactured in China nowadays. Not much you can do about it.
As to your main question, check out the latest WDTV Live. It will do everything you want but wireless. And that would probably be doable shortly with hacked firmware.
Diogen.
HD network media player
According to your demand, i think EHP-608 network media player is ok. I am using EHP-700 now. Until now i haven't found any problems of quality. As i told, it has gotten CE and FCC certificate. I think it's a nice player and very convenient. :angel:
(1) Full 1080i
I've got one of these: Amazon.com: Western Digital WD TV Live Network-ready HD Media Player?@@AMEPARAM@@http://ecx.images-amazon.com/images/I/415QukaExpL.@@AMEPARAM@@415QukaExpL
and I like it fine...
Onkyo 606 Problem
Need Help...screen being cut off...Pioneer Elite Pro-510
