New 12 Ft C-Band dish need advice | SatelliteGuys.US
leifkenn
60
Colorado
Hello,
I have posted a few other times and finally have my new BUD,
It is a KTI 12Ft Mesh with 2 Norsat 3220 LNB and a Chaparral Feed horn.
I have a few question that I was hoping could get answered.
1) What is still Available as far as C-band goes?
2)Which 1 SAT is the best to use for a stationary dish?
3) If I were wanting to get subscription stations would I have to get a 4dtv receiver?
Thank you
Leifkin:
There is a lot of stuff up there, check out the list
SatelliteGuys.US - TheList
I have a 10' CM parked at 99W for the networks, but there are other favorites.
With a positioner box from Sadoun Sadoun Powertech GBOX V3000 Positioner DiSEqC 1.2 Compatible
You can move your dish and get most of the birds
For subscriptions the DSR922 seems to be a big favorite, lots of features.
For $129 you can get a DSR410 from Skyvision, their packages start at $13/month
The others will tell you more
which Receiver moves a 24" actuator arm properly
which receiver can move a 12"-36" actuator arm motor
for a 3m/10ft dish properly without adding any boxes
16 years ago I owned a "strong" receiver
which had a built in positioner tp store satellite positions
it had a separate 24volt outlet to move a 12"-36" actuator motor arm
can any of these receivers move a 12"-36" actuator motor arm for a 3m/10ft dish
VIEWSAT FTA 9000HD - SONICVIEW FTA SV-8000
which is the best FTA receiver ...
-sam-
If your using a 12 foot dish you want to move it it's a waste on one bird. 4DTV's are out there you just have to look for them. There your best bet to sub to stuff. Get a 4D and a DVB receiver and you'll command the skys :)
-sam-
Use a old analog reciver or a 4dtv to move the dish, with a 4d you can grab a sub so that a plus, and there are a few DCII channels free, I would stay away from any viewsat or sonicview receivers they are poor, look for a Coolsat 8000/8100, Digiwave 9000 or the Pansat 9000, as these have been the best so far in North America.
Hello,
Thank you
First of all, very nice dish.
1) There is still quite a bit available. Alot of feeds still up there. Most of it has gone to DVB so you'll want to add a DVB receiver.
2) I agree with the other poster on this one. You want to motorize this dish and take full advantage of it. Otherwise you have a sports car that's not leaving 1st gear.
3) Yes
-sam-
Those won't move the dish. You would have to add a G box to move it with those. Otherwise you can find a cheap analog C band receiver on ebay or someplace to move it for you
3) Yes
Thank you.
I do have a DVB receiver it is a Coolsat 5000.I also have an old Cband receiver that will move the dish but am unable to find the remote. It is a Toshiba TRX-4400
Thank you.
Oh, well you are sitting in pretty good shape. Maybe add an HD receiver? Maybe you can find a remote for the Toshiba. What kind of programming do you like?
I like Discovery,Sci-Fi,History type channels No movie channels
Kids like Disney and Nick
You sound like a perfect candidate for a 410 subscription. You don't need to move the dish. You only need C band not Ku. The programming packs seem to have what you want at a reasonable price.
DSR-410 Digital Programming
Looks like the receiver will run you $130
DSR410 Receiver
I guess all of this makes the answer to your last question about needing a 4dtv to subscribe...... not necessarily
mounting a 6ft dish in a bucket of concrete
How to bring up older dish system
