New 811 problem | SatelliteGuys.US
New 811 problem
zoomer
50
10
My 811 just started something new, it will not go to stretch when I go from a HD channel to a SD channel. Whenever I would switch from a HD channel that I was watching with the display set to NORMAL when I switched to a SD channel the mode would automatically switch to stretch, but now stays on NORMAL. It also happens an OTA stations.
16x9. I tried to set it to 4x3 and then back to 16x9. There was no change in either mode. This is the first time this has happened. I even did a hard reset and still no change.
well there is a 4x3 #1 and 4x3 #2
if your tv is a 4x3 model, set the 811 to 4x3 #2 @ 480p and try that. you should regain control.
I got it fixed. I changed the output to 480P and then back to 1080i and now it is working right again.
One OTA (ABC) won't lock - any ideas?
Why use "Dual Mode"
