New antenna picture jumpy | SatelliteGuys.US
steve617
94
I have installed a new antenna and the picture is great and I have a strong signal. The audio seems fine but the picture is jumpy. Thanks for suggestions.
Steve
Yeah; DTV tuners don't get jumpy unless something is really wrong. If you have good signal strength, but there's a problem with the picture, it's almost always a cabling problem. Unless your tuner has gone bad, in which case you just need a new box or a new TV, as the case may be.
Could be a problem at the station, have you called them?
Have you talked to any other digital TV viewers in the neighborhood?
Is anyone else having the same problem?
Winegard PS-9370 needed with the Winegard MS2000
Need antenna amp
