NEW Dish Need help ! | SatelliteGuys.US
koko123
12
How are ya guys ....
I just bought a new 33" dish Q Sat, the dish have 3 diffrent holes:
Angle 18 - 65
Angle 60 - 90
Angle 0 -20
My question is what hole should I use?
To make sure I have everything right my (Latitude is 42.3 and longitude is 71.1) what number should be on the dish and what number should I use on the SG2100?
My last question I have Fortec Star Lifetime Ultra Receiver, and I have Digiway (DG780) KU Band LNBF, should I set my Fortec to Standard or Univ ?
Thank you soooo much in advance :yes
I would use the 18-65 angle...that would cover most of the US :)
Check on the LNB for any markings for frequencies…when in doubt, use standard : )
On the SG2100 use..........
Motor elevation = 48 deg. (one side of the motor is deg. and the other is Lat.)
Dish Elevation = 24 deg.
great thank you ... on the dish there is 2 diffrent numbers top and bottom and they don't go together what should I use ...
Guys I have the TV outside :eek: ... quick question should I point bat AMC 6 or SBC 6 ?
any live feed on AMC6 or what freq should I uses to istall the true south ...
Thanks guys
DG5900C and Coship CDVB5300A seem to be the same unit!
How to a satellite to Samsung DSR3800
