New Home Construction | SatelliteGuys.US
Zeptune
13
Sacramento
Hello,
I will be moving my dish network service to a new construction home in the next 6 months.
Right now it's time to pre-wire low voltage in the home.
A couple of questions...
1) How many runs of RG6 should I put from where the dish will go to my structured wiring panel. Last I heard 4 was the number. Just checking to see if anything has changed.
2) Any feedback on how you would pre-wire a new home if you had the chance?
I am currently deciding to NOT do the "room with all the components in one room" concept. Has not worked will for me in the past. I will home run everything to a structured wiring panel. I currently have a 722 receiver and we will have TV's in at least 4 rooms. (We don't need to watch more than two channels at once.) Open to expanding HD in the most cost effective way.
Appreciate any feedback.
Thanks,
Zep
In the past I have overwired when it was new construction and I had easy access. Now whether new or old construction, I just run 2 RG6 and 2 CAT6 from my wiring closet to all rooms and 1 RG6 outside to back patio. 1 RG6 to the attic for OTA, 1 RG6 outside for Cable/Internet and 3 RG6 to my Dish location.
I also wired living room/media room for surround sound and back patio for sound too.
I just bought a new house, so I get to do it all over again in 5 weeks.
run oversized conduit to all posible locations. conduit is cheap, and flexible.
like when the direct, dish merger occurs, yoou can change your cables as needed....
theres going to be a consolidation of the pay tv market. best to be prepared...:)
Three cables from the dish location, and if you want/have available OTA, one from where the antenna would be located....not necessarily next to the dish.
Dish Continues to Lose Pay-TV Subscribers
Dish Anywhere - someone else's info
