I am hearing we might get a modified version of last nights upgrade tonight![]()
Well the new version 120 did fix my playback issue, when pausing live tv or rewinding, when going back to live, I use to get a pause (a few seconds) before the video would sync up, now it is correct.From thread http://www.dbstalk.com/showthread.php?t=78130 Earl is saying:
THERE WILL BE AN UPDATE WINDOW TONIGHT
Monday, January 29, 2007 between 11pm - 1:30am EST
However... it might not be Benz - 0x11F
Your feedback on 0x11F has already been looked at, and worked on.
Seriously... you all said you wanted to make a difference, well... you are.
There is a reasonable chance, that tonights build... will be a Benz based build, with some of the things you already found... corrected.
I will probably get confirmation by 10:30pm (EST), what version is going to be there.
How does one tell what software version is on thier HR20?
I was not available to download this new update.. o well.![]()
Ugh, me neither. And my HR20 missed 2 recordings last night AND gave me a black-screen for a 3rd....did a RBR and other things but to no avail.
Guy's incase you are on the boards, the update IS still in the stream tonight !
Thanks Mr.Smith, saw one of your posts tonight !
Jimbo
As I noted elsewhere, I had very poor service dealing with the update. The tech person had me erase the hard drive and force download the software, only to be caught in an endless reset loop (it wouldn't download satellite information or guide data). They finally decided that the box was bad and are sending a replacement. When I went to bed last night I unplugged the box. When I got up this morning, everything was working again! I frankly don't get it, although the box did download guide data, so I guess it's working. I'm not very confident though, after all the problems I had yesterday.
Limited time offer
