New LNB | SatelliteGuys.US
New LNB
leomarion
14
Just checking to see if anyone has any info on the new dishpro LNB. It is supposed to combine feeds onto one line like th edpp44 but be more cost effective. Anyone have a model number or anything for that matter.
Ronnie
You're probably thinking about the DishProPlus Twin LNBF.
You can think of it as a DP Twin with a built-in DPP32 switch.
That is DP PLUS features, 3 inputs (110, 119, plus one other bird of your choice), 2 outputs, each able to use a DPP Separator.
It'll be great for the standard DHA 4-room install using 2 x22 receivers.
To complete the package, a stand-alone FSS dish for 105/121 installs would be great, but I doubt it'll happen - because that's not a "one-dish" solution.
Thanx. When will this be available?
chaddux said:
Better to just edit your post.
Hadn't even noticed that I could. Thanx for lettin me know
reg connections of lnbf
Possible bad SW64? Is there anything I can do to bring it back to life?
