New Member question on availability | SatelliteGuys.US
BJL1942
rural, pa
Hi all,
I have been digging through the site and there is some great info. Thanks for all of it. Here is my question, I recently moved from Denver (where I discovered OTA HD and loved it) to rural PA, 15853 is the zip and Antennaweb tells me I am out of luck that there are no stations available. My question is I know there are towers within 100 miles as the crow flies, problem is the crow goes over hills and vallys. Is there any setup that would help me out or am I indeed outta luck?
Thanks so much,
BJ
welcome :wave
I did run a tvfool report for your zip and hate to tell you but there isnt much
TV Fool
PBS shows as you can pick it up but the rest are way distant and would take some extreme measures to possibly get them
OTA antennas
Minneapolis Fox & My channels having tower work done
