GEOSATpro - New microHD Firmware Release: GSPMHD_20130218 Available for USB and Satellite Update (OTA-SSU) 2/27/ | SatelliteGuys.US
GEOSATpro New microHD Firmware Release: GSPMHD_20130218 Available for USB and Satellite Update (OTA-SSU) 2/27/
SatelliteAV
6,486
186
Roseville, CA
February 27th, 2013
Minor Firmware Update is Available for Expanded Satellite List and Minor Coding
GEOSATpro firmware GSPMHD_20130218 for USB Update and maincode 2013-2-18 for Satellite Update
(via Galaxy 19, freq. 12115, PID 330)
Warning: The GSPMHD_20130218 / maincode 0.1.4 2013-2-18 update is a main system file and will overwrite your settings and channel scans.
We strongly recommend users to perform a Factory Reset and Remove the Power Plug for 10 seconds to power cycle the STB after the firmware update is completed.
Important Clarification about loading .udf files created with previous firmware versions. We DO NOT recommend loading old User Database files (.udf) that were saved on previous firmware versions older than 0.13. While the saved .udf file may be fine and cause no operational issues, the file could contain data that will cause the microHD to enter a reboot cycle. Please follow our recommendation of rebuilding your channel list using the database file that is in this firmware.
You may safely load any User Data Base (.udf) file created and saved from a microHD operation on firmware version 0.13 or newer. If you have an older User Data Base created with firmware older than 0.13, use the attached new Satellite/ Transponder list. If you use a switch or motor, you will need reconfigure and re-enter your location Longitude and Latitude settings.
MicroHD Firmware Notes:
Date: 2/18/2013
Version: GSPMHD_20130218 / maincode 0.1.4 2013-2-18
  • Attached Expanded Satellite List
  • Miscellaneous Code Cleaning (no operational changes)
GEOSATpro USB has stopped functioning
GEOSATpro For the folks who got their MicroHD
