New Pentagon Channel mux INCLUDING HD on 101w Ku | SatelliteGuys.US
Jim S.
When someone asks you if you're a god, you say yes
5,799
1,546
FN11od
Dunno why they put it here instead of on 103, unless they're going to raise the price on 103 for the new satellite, but there it is...
11820 H 20000, the SD and SD-with-Dolby channels are still MPEG2, the HD channel is MPEG4, and there's also an encrypted channel.
Nice now I got to re scan 101 when pawn stars goes off.:D
Are they still testing? Not able to pull Pentagon HD channel, in but the SD Pentagon still come in nicly at around lows 70 here in New Mexico....:hungry:
It was up when I checked about an hour ago. You're looking at 101 instead of 103, right?
Yes Jim S,
I am at 101*W and I know it's a funny offset bird, since my feedhorn it's alway set at 0% fixed so I wil keep nugging my motor to home in the signal.
You said you were getting the SD version, did you mean you were getting it on 101? There's no reason you shouldn't be getting the HD version too then (unless it went down for some reason). The HD version is MPEG4, but it's on the same transponder as the SD and SD-Dolby one, along with an encrypted channel called BACKHAUL the last time I looked.
What am I doing wrong?
New Openbox S10 File (DiSEqC Fix) Posted July 19th
