NEW PRODUCT: Fortec 90N new dish 90cm (36") | SatelliteGuys.US
Sadoun
2,320
Columbus, OHIO
Hi All
We just got a new shipment of Fortec's NEW 90cm dishes (FC90N).
  • This dish measures around 37" by 33.5"
  • One piece strong back bracket
  • Universal Wall Roof mount with Side Struts supports
  • Flat edge
  • Made at Fortec's new Dubai factory
And still a cream color, I see.
Thought they were moving to a charcoal, as in their bigger dishes?
Well, it looks nice.
Send one over and I'll compare it to the old one I got 3..4 years ago, and an un-named charcoal 36'er. - :cool:
Your web site has a typo for the gain. It lists
Higher KU band signal gain (33.34 dB) than the competition.
But the specs show
KU – Band Gain @12.5 GHz
39.34 dB
To me it seems as if it should really be called a 85cm dish and not a 90cm, as its effective aperture would be slightly less than the 85cm width. Since the dish is an offset dish, the height (90cm) appears to be smaller when the satellite looks at the dish because it is tilted.
No matter what the dimensions, it's the gain factor that is important.
This is just a pet peve of mine as the different manufacturers use different parameters in the naming of there dishes. One manufacturers 85cm dish can be actually bigger than anothers 90cm dish. You have to read the specs carefully to really find out what you are buying, with the gain factor being what really counts.
Pansat 9200 HD with existing service
How to downlink SatMex 6 in PAL?
