New Receiver Suggestions | SatelliteGuys.US
luisortega
5
Iowa
We have an HR23 in the living room as well as 3 D12's. I want to upgrade the HR23 to an HR24 and replace a D12 with the HR23, is it as simple as just swapping them out and having them activated? The HR23 now is connected with a SWM and the house is already wired for CAT5.
From what I understand this resets the contract another 2 years? I've tried but can't get any deals from Directv, plus they wanted to charge $49 for installation. If I went with just an H24 I know I can watch the HR23's recordings but can I set it to record too?
First off, :welcome to Satelliteguys!
It is as simple as moving the HR23 to where the D12 is and putting the HR24 where the 23 is. You are right, it will give you a new 2 year commitment. I'm not sure about your last question since I don't have mrv myself.
Assuming the dish is pointed properly then yes it is plug and play.
Assuming all SWM components are "Green Label" then yes all you have to do is have them activate MRV.
Installer put the HR24 and H24 on the wrong TV
Connected to the Net
