New Remotes - Old Rec's | SatelliteGuys.US
Jimbo
Cutting Edge
Jul 14, 2005
70,060
8,415
NW Ohio - Buckeye Country
Can a Newer RC32 remote be set up to work with a older RCA 435 rec ?
Also would like to be able to work the input on the Sony TV as well.
This is a rec. at the cottage so I haven't changed it out to HD as I don't need HD up there.
Jimbo
Jimbo
Yes, the code would be 00392 for the RCA receiver. If the receiver were to set to DSS2/SAT2 code, then you would use 00855.
You would use sony tv code 10000, once you programmed to get the tv input:
1. tv
2. press and hold MUTE & SELECT for two blinks
3. enter 9 6 0
1. tv
3. enter 9 6 0
Thank you very much Edmond
So if I set the RC32 on D* and then did the Mute/Select thing, then push the 00392 ?
Is that correct ?
Then do the Sony TV code after that ?
Jimbo
Resetting a locked H20
CSTV and Tennis channel HD are on
