Has anyone tried this software? I came across it on ebay of all places.
rdel
http://www.al-soft.com/saa/satinfo.shtml
rdel
You can show an angle by using the Degrees (360) Minutes (60) and Seconds (60). A Degree is made up of 60 Minutes and a Minute is made up of 60 Seconds.
Using Seconds for FTA is a bit of over kill. IMHO
Bob
Okay, I just hadn't seen that before.. Can I put both minutes and seconds on zero and leave it that way.. Thanks
geesh, and I thought you were a pro.I usually just round it up or down to the nearest degree!
Well, that's still just 1/3rd of a percent... :upgeesh, and I thought you were a pro.![]()
Limited time offer
