New setup intermittent | SatelliteGuys.US
NWLanding
2
Olympia
In December I replaced my Hopper 2 with a 3 for use with my Winegard SK-1000, A DHP42 switch with power inserter was installed. I lost sat 129 and HD channels. I replaced the DHP42 switch and it worked for a bit, then failed again. I swapped some cables and had success, then it failed again. I'm shooting blind at trying to figure out how to break this problem down to fix the problem. Any ideas would be much apreciated.
My brother in law had this problem he travels all over. 129 is very low in the horizon. He spends about 4 months a year in one place at that location he uses a standard dish which is always there, not the traveler and all works totally fine. When he is on the move. is works sometimes and sometimes not. Hope this helps
Reactions: kd4eai
Perhaps he should buy an Eastern arc dish and lnb so that if he is toward the eastern seaboard he can dial in the 61.5 and 72.7 satellites instead of the WA 110/119/129 sats. Not a lot of money required to do that.
Using Channels DVR with Dish Anywhere as a source
Can an ATSC 3.0 Tuner Replace a Dish OTA Dongle?
