NEW SG2100 and Invacom setup! | SatelliteGuys.US
yonder333
13
Miami
hey i live in hialeah Fl and i can't get any of the linear satellites all the signal i get is from 82,91,110 and 119 W.I'm using a SG1200, 30" Dish and a invacom QPH-031 lnb. I need help to get the other satellites
WOW! What are you getting FTA on 82-119w ?
Make sure to hook up to a Linear output of the Invacom QPH-031 and set your L.O. to 10750
I'm hook up to the linear and i still don't don't get signal from any linear sat what am I donig wrong
If you are using the correct L.O. (LNB Freq) 10750 then you will have to use a LIVE TP. and then move the dish until you see signal QUALITY!
Its not as easy to find a Linear satellite as it is to find the MUCH stronger DBS satellites!
You never did tell us what channels you get on DBS 82-119w?
Hey can u send a link where i can read and get familiar with all this (LIVE TP and LO terminology) please and a better guide than the one i have because i ain't getting no luck with this linear stuff. TY PSB for ur help
ok this is what i've done so far. set my motor at 65 elev, and my dish at 24.and with skew in 0 i put it to the south and i get 82w what i do from there.my diseqc seems to b bad
AMC-5 @ 79ºW Would be the best Linear satellite to use, its close to your true south!
I would remove the motor and try to find this satellite at the below angles, only then add the motor.
http://www.lyngsat.com/amc5.html
Code:
                      Hialeah, FL 33016
         Latitude 25° 52.818'N Longitude 80° 20.208'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Amos 1/2    4.0W  96.1 101.9  3.6 -63.5
                Atlantic Bird 3    5.0W  96.5 102.4  4.5 -63.4
                Nilesat 101/102    7.0W  97.4 103.3  6.3 -63.1
     Telecom 2D/Atlantic Bird 2    8.0W  97.9 103.8  7.2 -63.0
                     Express A3   11.0W  99.3 105.2  9.9 -62.6
                     Telstar 12   15.0W 101.3 107.2 13.6 -61.9
                   Intelsat 901   18.0W 102.9 108.8 16.3 -61.3
                          NSS 7   22.0W 105.1 110.9 20.0 -60.3
                   Intelsat 905   24.5W 106.5 112.4 22.3 -59.6
                   Intelsat 907   27.5W 108.3 114.2 25.0 -58.7
                  Hispasat 1C/D   30.0W 109.9 115.8 27.3 -57.8
                   Intelsat 801   31.5W 110.9 116.8 28.7 -57.2
                   Intelsat 903   34.5W 113.0 118.8 31.4 -55.9
                    AMC 12/T 11   37.5W 115.2 121.1 34.1 -54.5
                        NSS 806   40.5W 117.6 123.5 36.7 -52.9
                      Pas 3R/6B   43.0W 119.8 125.6 38.9 -51.3
                         Pas 1R   45.0W 121.6 127.5 40.6 -50.0
                   Intelsat 705   50.0W 126.7 132.6 44.8 -46.2
                   Intelsat 707   53.0W 130.2 136.0 47.2 -43.4
                   Intelsat 805   55.5W 133.3 139.2 49.0 -40.9
                          Pas 9   58.0W 136.7 142.6 50.8 -38.1
                       Amazonas   61.0W 141.2 147.1 52.9 -34.3
                     EchoStar 3   61.5W 142.0 147.9 53.2 -33.6
                      Rainbow 1   61.5W 142.0 147.9 53.2 -33.6
               Estrela do Sul 1   63.0W 144.4 150.3 54.1 -31.6
                   Brasilsat B2   65.0W 147.9 153.7 55.2 -28.6
                   Brasilsat B1   70.0W 157.3 163.2 57.6 -20.3
                       Nahuel 1   71.8W 161.0 166.9 58.3 -17.0
                      DirecTV 1   72.5W 162.5 168.4 58.5 -15.7
                          AMC 6   72.0W 161.4 167.3 58.3 -16.6
                          SBS 6   74.0W 165.7 171.6 58.9 -12.8
                     Echostar 4   77.0W 172.4 178.3 59.5  -6.8
                          AMC 5   79.0W 176.9 182.8 59.7  -2.8
                      Nimiq 2/3   82.0W 183.8 189.7 59.7   3.4
                          AMC-9   83.0W 186.1 191.9 59.6   5.5
                   Brasilsat B3   84.0W 188.3 194.2 59.5   7.5
                          AMC 2   85.0W 190.6 196.4 59.3   9.5
                          AMC 3   87.0W 195.0 200.8 58.8  13.5
                           IA-8   89.0W 199.2 205.1 58.2  17.2
                      Galaxy 11   91.0W 203.3 209.2 57.5  20.9
                     Nimiq 1/4i   91.0W 203.3 209.2 57.5  20.9
                   Brasilsat B4   92.0W 205.3 211.2 57.1  22.6
                           IA-6   93.0W 207.2 213.1 56.6  24.3
                      Galaxy 3C   95.0W 210.9 216.8 55.6  27.6
                           IA-5   97.0W 214.4 220.3 54.5  30.6
                      Galaxy 4R   99.0W 217.7 223.6 53.3  33.4
                     Spaceway 2   99.2W 218.1 223.9 53.2  33.7
                DirecTV 1R/4S/8  101.0W 220.8 226.7 52.0  36.0
                          AMC 4  101.0W 220.8 226.7 52.0  36.0
                     Spaceway 1  103.0W 223.7 229.6 50.6  38.5
                          AMC 1  103.0W 223.7 229.6 50.6  38.5
                         AMC 15  105.0W 226.5 232.3 49.2  40.7
                      Anik F1/R  107.3W 229.4 235.2 47.4  43.1
                      DirecTV 5  109.5W 232.0 237.8 45.7  45.1
                EchoStar 6/8/10  110.0W 232.5 238.4 45.3  45.6
                        Anik F2  111.1W 233.7 239.6 44.4  46.5
                  Solidaridad 2  113.0W 235.8 241.6 42.9  48.0
                       SatMex 6  113.0W 235.8 241.6 42.9  48.0
                       SatMex 5  116.8W 239.4 245.3 39.7  50.8
                         AMC-16  119.0W 241.4 247.2 37.8  52.2
                     DirecTV 7s  119.0W 241.4 247.2 37.8  52.2
                     EchoStar 7  119.0W 241.4 247.2 37.8  52.2
          EchoStar 9/Telstar 13  121.0W 243.1 248.9 36.0  53.3
                     Galaxy 10R  123.0W 244.7 250.5 34.2  54.4
                      Galaxy 14  125.0W 246.2 252.0 32.5  55.4
                  Galaxy 13/H 1  127.0W 247.6 253.5 30.7  56.3
 Intelsat Americas 7/Echostar 5  129.0W 249.0 254.9 28.8  57.1
                         AMC 11  131.0W 250.3 256.2 27.0  57.9
                      Galaxy 15  133.0W 251.6 257.4 25.2  58.6
                         AMC 10  135.0W 252.8 258.7 23.4  59.3
                          AMC 7  137.0W 254.0 259.8 21.5  59.9
                          AMC 8  139.0W 255.1 261.0 19.7  60.4
                   EchoStar 1/2  148.0W 259.8 265.7 11.5  62.3
       Satellite Finder is (c) Copyright 2004, P. Lutus
When you do add the motor use.......
Motor elevation = 64º
Dish on motor elevation = 26º
The dish elevation may need changed to peak in the signal but the motor elevation should never be changed!
Thank You PSB I'll try it like that. one last question can i move the motor angle in case that i find the AMC5 in a lower angle?
No never! As long as you are sure the mast/pole is level all round all you will need to move is the dish elevation slightly up or down to peak in the signal.
If you change the motor elevation you will not track the satellites (Clarke Belt) accurately!
ok i check lyngsat and yes is has same channel as teh ones i just scan now can u help me setting the rest of the satellites.coolsat 5000 plat, invacom quad, 30" and getting AMC-5 with 90 % quality and level
Well done!
If you are using USALS make sure to have your Latitude (North)and Longitude (West) entered correctly before moving the dish with the motor, when you change to another satellite in the antenna set up screen the dish should move to that satellite. Then do a blind scan.
You may have to use DiSEqC 1.2 for some satellites to the far East and West of your arc. You will have to use a LIVE transponder then motor until you see max. signal quality, then you can number and store the satellite/position.
TheTube Network ??
homemade mount for 2nd circular lnb
