New Sirius user with question about plug and play units and FM frequencies | SatelliteGuys.US
Tech27
89
Hi, New Sirius user here and I had a quick question about the fm frequencies when tuning in a plug and play unit. I have the new sanyo unit and not sure if better to tune to low or high. which gives better sound through radio?? 88.1 or 107.9??? Thanks in advance for any input.
Thanks dfergie, I'll just be sure to try a spot that is away from a near used frequency.
VonL said:
How can I hardware my plug-n-play unit? I have the JVC KT1000. Thanks,
If your head unit, the radio in the dash has a AUX in just use a audio patch cable.
Otherwise use a wired modulator. A wired modulator is placed inline with the normal AM/FM antenna coax. Just unplug the antenna coax from the radio and plug it into modulator, then plug the antenna output from the modulator into the radio. 12v DC power will have to power the wired modulator.
A easier way is to use a cassete adaptor if you dash radio supports it.
