New Slimline Pole | SatelliteGuys.US
New Slimline Pole
StarScan
438
59
North Liberty, Indiana
I made this pole last year in high school and thought I'd share. Today I started transplanting some dishes and this was one of them. Added some concrete to the base and filled the pole as well.
just remember the higher it goes the more wiggle it'll have. provided its level when you plant it and have enough cement on it, shouldn't be an issue. just food for thought when the wind picks up.
the lower half has fins welded on it for just that. the upper half is welded to the lower half. i don't think it'll be much of an issue.
Ah, ok, didn't see the bottom half close enough !
You should be good !
Make sure it's plumb when you set it and more importantly, it is when you put the dish on it.
Setup for 32 tuners with 2 SWM-16's and whole home?
Do you know any dealers that work with DirecTV and Dish Network?
