New Software APJ1 | SatelliteGuys.US
New Software APJ1
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,713
29,486
Newington, CT
Got new beta software tonight. :)
Noticed a few things...
New network settings screen, looks a little cleaner but is still not pulling an IP address from my router. In order to get an IP I need to click Reset Connection, it then quickly grabs one However my Sling features still don't work... I have a feeling it could be that because the box is not getting an ip at bootup that it does not turn on the Slingbox function.
Another thing I noticed on the system info screen is there is now a spot for TV1 IR Address! I hope that's a sign of things to come.
MSNBC works now, although if you try scrolling down the screen, the entire screen moves down instead of just the web content. Whoops. :)
Every release just a little nicer looking.
I was also able to put in in single tuner mode and do PIP, I wasn't able to do that before.
dpp33 says its a sw64 on system info
