According to Dish's technical page, new software is spooling for all 322 receivers. The software version is 1.52. Anything new?
I noticed this software change also and believe it will create more of the same problems I'm having on TV1 with TV2 see post above for details.lloyde6 said:The screen saver comes on when I turn tuner 2 off and stays on until I turn tuner 2 back on. Is this normal? It is not a problem for me but it just started doing this yesterday and I didn't know if maybe it was part of the newest software download or if something is going wrong with my receiver. Any answers for this? Thanks
It doesn't seem necessary to me but has not been a problem for me yet. I just wanted to make sure it wasn't just on my receiver , meaning something could be wrong with it. Thanks for the input.sirlurkalot said:Update to the changes I've noticed...
When you think you've turned "off" the unit on both tuner 1 and 2 it then stll displays a video image of the "floating DISH" and says "press select to continue".
Seems that select is now a new "power on" button on the remote!
I'm sure this should be corrected in the next update? Seems nuts to me!
Limited time offer
