This moring Wilt posted to the Yahoo group about who will get a new Dish which can view the second satellite which goes into operation in March.
If I am reading between the lines here it almost seems as though the get the channels on the second satellite and get the updated Dish we will need to upgrade out programming tier to a new tier.
I do hope I am reading between the lines correctly, is anyone else seeing this?
It's going to be an interesting CES next week.
Well, likely not correct.
If services are put on the other bird, and they're meant to be part of the
service, either this level or a newer one, then, by definition, unless one
already has a multisat dish-pointed properly-- it will be necessary to get
another dish-multisat or single-to "see it.
I think some of the stuff here may be because some/all of the lineups
aren't done yet so it's difficult to say what will trigger the need or if
you'll need one to just keep your existing level of service, etc.
Best advice I can give right now is just hang in there, you'll all hear
about it soon enough when it's ready
