New to FTA | SatelliteGuys.US
New to FTA
kspilot
46
KANSAS
I am thinking of buying the CNX Nano2 and the dish package from Sadoun which has the 36"dish,280b motor and LNB.
What do you guys think of this setup?
Also,im buy this primarily for viewing the AMC 9 satellite to watch the old TV shows.
I might be installing this dish on the east side of my home and up close to the house,on a pole in the ground,that way the coax length will be shortened better than way out in the yard,the bad thing about this is the satellite will only see from 0-190 degrees,will this be ok or is there a lot of satellites beyond 190 degrees to the west?
All comments appreciated!
Oh by the way,im in Wichita,Kansas
The CNX is, from what I can tell, primarily for the pirate trade. You can probably find a used Coolsat on eBay for less money, which will be a ,uch better bl;ind scan unit....
Keep reading about the boxes. You might want to keep reading about dishes and motors, too.
A 180 degree view is optimist. I always knock off 15-20 degrees in each direction because of earth interference. I would consider 27-167W more realistic
The furthest west KU sat right now is 127W
129W is no longer there and 127 really doesnt have anything on it.
I bought the motorized package from Sadoun with the 36" dish and GeoSatPro 200. It works great! Can't recommend the equipment, and the company, enough!
My 1 meter CM install
Best value for PVR with atsc tuner? (+ basic q)
