New to fta | SatelliteGuys.US
New to fta
trapper1014
Bancroft maine
I just bought a Geosat pro from eBay. It is now mounted and I aimed it to Galaxy 19 and then to Amc 6. I can't get ANY signal. I get 45% on signal strength. Any help is appreciated
Welcome to SatelliteGuys Trapper!
We would be glad to help you get it going.
First of all how do you know, your dish is pointed properly at G19 or AMC6?
When you say GEOSATpro do you mean a dish or receiver or both?
If a dish what receiver are you using?
If a receiver what dish are you using and LNBF?
Sounds like a receiver or at least an ALi chip-set.
On Signal strength is can be a little misleading. If you have 0% it means no LNBF or a bad one or bad connection.
If you have 45% then it is detecting a LNBF/LNB.
80-90% mean you have a signal of some kind.
Now that is all under signal strength, which like I said can be misleading.
The thing you want to look for is the quality bar. When it starts lighting up that means you have actually detected a signal.
That is the one that you want to peak on.
Is your LNBF skewed in the holder for G19 or AMC6?
Go to dishpointer.com and enter your address and then select the bird you want to shoot for and it will tell you the skew.
It will also tell you the elevation and azimuth for your dish.
I hope this helps. Feel free to ask all the questions you need. :)
Also need to be watching the tune up screen on a valid active transponder.
program in (if not in your transponders) and watch Freq 12152, Horizontal polarity. 20000 SR (Serial rate) for 97W (Galaxy 19)
Once that is maxed out perform a blind scan to get the rest.
To 'fine tune" find the one with the lowest Quality reading and try to get it higher.
(Boy my finger have had dyslexia, edited out the spelling errors)
Reactions: KE4EST
Welcome Trapper! Over time you are going to enjoy this great hobby. There will be times when nothing wants to work and other times when everything works like magic. Read everything you can about how all this works and never stop reading and asking. Have fun!
Keep us posted, the more details on setup the better, pictures welcomed, and as others have said, "Welcome!" The members here are the BEST!
97W went dark
H&I goes out several hours nearly every evening
