New Update | SatelliteGuys.US
New Update
lacubs
1,596
42
Erie, Pa
i got a new software update today, what did they update? i get mad when it down your icons and its take a few days to show back up
What update is it ?
Software version ...
Sent from my Samsung Epic using SatelliteGuys
From the tech I spoke to earlier today, "it's just a bunch of bug fixes".
The only difference I can see is that now none of my VOD services work on my HR24-100.
same here, but when they do these update it might take few hours to redownload
found it, Receivers included in this release: HR20-700 • HR20-100 HR21-100 • HR21-200 • HR21-700 • HR21Pro HR22-100 • HR23-700 HR24-100 • HR24-200 • HR24-500 R22-200 • R22-100 Staggered Release started 8/11/2011 The Contents of this Release: (Differences based on previous national releases) New features * None Updated * Improved Stability
In my case, few = 27. Update at 2:20 am 8/17, they were still not working at noon on 8/18, but they are now working @ 5pm. So, hooray. Just needed to have a bit more patience.
Usually they tell you to wait 24 hrs and if you have any issues after that, then report them.
Hmm nothing major it seems as I have had 0x4d1 since 7/29 and didn't even notice. same reliable speedy unit. everything still works
Where'd my VOD go? (HR24)
Suspend 1 receiever
