New VIP722K initial configuration help | SatelliteGuys.US
ddsp
6
Pennsylvania
I plan to replace my older 625 with a VIP22K which I recently purchased.
I did check the smart card number on the barcode label and it does start with S19 so I apparently do not need to contact Dish for a card before I start to install it.
This is for our vacation home and my plan was to test it out before we leave for the shore. I don't use DISH here, but I do have a spare antenna that I was planning to temporarily set up to test out the receiver.
I did a very dumb thing - I followed the instructions on the screen.
It immediately went into a configuration process and, at step 3, it is trying to get information from the satellite(s). OOPS!
So, is there a way I can interrupt the automated configuration? (I tried restarting the system and it always goes to the same step.) If I do, will I be able to access the menu system and point the antenna?
Otherwise, I'll wait and spend part of my vacation getting the new receiver set up.
Thanks,
ddsp
Hey Dish, We need it quickly or somebody else will
? on contract.
