What was probably happening was a customer knew Dish offered ESPN HD or Showtime HD but expected them to be in the same area as the other ESPN or Showtime channels. They'd tune to regular ESPN and think they were watching "HD". Dish had to dumb down the program guide two ways: One, adding the HD watermark over the channel number and two, putting the two right next to each other, even with the same channel number.
I don't see how you figure it is "dumbing down". The channel numbers are total artifice anyway. As long as they have to pull a number out of their butt why not pick one that makes sense to the viewing public?
By the way anyone: Is it possible or likely that other than making massive favorites lists that there will be an option to delete the extra nonsense 9000 numbers?
You can lock the channels then select "hide locked channels". When you do that they don't appear in any of the menus.
Why would he?but that will remove the map downs which is fine with me, but the orig poster seems to prefer them
I do call it dumbing down. People clearly couldn't find the HD channels up in the 9000-range. Remember, thousands and thousands of customers, Dish's included, hook their 311 receivers up to their new HDTVs and "they're watching HD now".
Limited time offer
