Actually, one of the LNBs on that dish should be suitable for FTA use.
Is this a 121º SuperDish?
If so, there are two LNBs mounted on two "pipes", which are attached to each other.
The LNB on the
bent pipe is marked
FSS.
It's a bandstacked LNB which will get you some FTA.
If this is the 105º Superdish, I think the appropriate LNB has ....
Well, I suggest you paste in a picture of the LNB bundle on that dish, and we can guide you better.
I'm a little rusty on my dish descriptions. -
edit: and this is not to say you shouldn't get a more appropriate dish, LNB, and aim the thing correctly.
Just as was so wisely recommended above...
But if you want to get your feet wet, and get sucked into the hobby, this dish will probably do the job.
