Newbie FTA Install - It was cake! | SatelliteGuys.US
Mark_AR
1,448
North Arkansas
Well I have my FTA system installed.
You can't believe how lucky I was.
As soon as I flipped on the 2500 and did the initial antenna setup, it said I had 85% signal strength and 35% Quality. I bumped it a few notches W and have 75% quality without any declination/skew adjustments. I have it pointed at T5 right now. I ran out of daylight and the skeeters are pretty thick. So tomorrow I will do some more tweaking. *itch*itch*scratch* :D
So far I can see over 100 TV and 40+ audio channels. Too bad I don't understand a damn thing they are saying.. *grin*
I still have to figure out how to move the dish. :confused:
I'm not one to RTFM. (Read the *bleeping* manual) ;)
Just wanted to report on my luck setting it up. :p
you must be on IA5 (T5) :)
It isnt too bad as long as you have elevation right and know approx where azimuth is.
