newbie help.Totally lost!!! | SatelliteGuys.US
jayco101
2
northern Illinois
Totally lost!!! I have a new Dish service the 2 TV- 100.4 mpeg 4 with the vip722K DVR The dish is the DishPro. The service guy set it up to the eastern Arc. 77--72.7 --61.5 Satellites. I ask for and received a second Dish pro complete so I could use the vip722k in my camper.
The problem,When I set it up in my camper I get a message that I am receiving fewer Satellites and will receive fewer channels and my choices are ( save this setup) (cancel ) or( retest )( the retest gets the same options.my question is,If I save the set up with fewer channels on my camper dishpro setup will I get the option to go back to my regular setup with all the satellites and channels when I hook back up to my DishPro dish at home when I hook the vip722k up to it or what can I expect. I have changed nothing as of yet.Oh I used a peak meter to set up my camper Dishpro dish.Like I said totally lost with no clue.
Do the "save this setup". When you reinstall it in your home you'll just have to do a check switch and it'll pick up all 3 satellites and all of the channels you subscribe to. Your camper install probably only "sees" 1 or 2 satellites so you won't get all the channels there. If you get in trouble just post back here & someone will help you out. By doing the "save this setup" thing you're not doing anything permanent, you can change it by doing a check switch. Hope this helps.
Welcome aboard!:up
Ed
If the "second Dish pro complete" is also a Dish 1000.4 as implied, you have either an aiming or line of sight issue.
If it's a lone LNB or a Twin, the message is to be expected and you should choose save. The Check Switch routine needs to be done each time the receiver is moved to a different LNB/switch configuration.
Thanks to both of you .You just got a aun happy wife off my back.
And yes Bobabird both dishes are the dishpro1000.4 style.I'll be more precise in my setups on the camper. Thanks for the replys
722 OTA with square shooter
Problem with no info in guide for WBNS 10tv HD
