Newbie need help setting up Pasat 2700a with Stab Rotor Sat HH 90 motor | SatelliteGuys.US
MonkeyCMonkeyDo
7
I new to FTA and try to set up my Pasat 2700a with Stab Rotor Sat HH 90 motor. My location is 54914 ( that's in WI).
I read most of the forum about setting up a true south...but I still confuse. Please help. Thank.
Check here for installation help...........
http://sadoun.com/Sat/Products/STAB/HH90-Stab-HH-Diseqc-USALS-Motor.htm
It may be an idea to find and store a few satellites before adding the motor, including your true south satellite IA-8 @ 89w
Code:
                      Appleton, WI 54914
         Latitude 44° 16.260'N Longitude 88° 25.956'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
                   Intelsat 905   24.5W 108.9 112.3  9.8 -42.7
                   Intelsat 907   27.5W 111.2 114.7 11.8 -41.9
                  Hispasat 1C/D   30.0W 113.2 116.7 13.6 -41.2
                   Intelsat 801   31.5W 114.4 117.9 14.6 -40.7
                   Intelsat 903   34.5W 116.9 120.4 16.6 -39.7
                    AMC 12/T 11   37.5W 119.5 123.0 18.6 -38.5
                        NSS 806   40.5W 122.2 125.7 20.5 -37.3
                      Pas 3R/6B   43.0W 124.5 128.0 22.1 -36.2
                         Pas 1R   45.0W 126.4 129.8 23.3 -35.2
                   Intelsat 705   50.0W 131.3 134.8 26.3 -32.5
                   Intelsat 707   53.0W 134.5 137.9 28.0 -30.7
                   Intelsat 805   55.5W 137.1 140.6 29.4 -29.1
                          Pas 9   58.0W 139.9 143.4 30.6 -27.5
                       Amazonas   61.0W 143.4 146.8 32.1 -25.3
                     EchoStar 3   61.5W 144.0 147.4 32.3 -24.9
                      Rainbow 1   61.5W 144.0 147.4 32.3 -24.9
               Estrela do Sul 1   63.0W 145.7 149.2 33.0 -23.8
                   Brasilsat B2   65.0W 148.2 151.6 33.9 -22.2
                   Brasilsat B1   70.0W 154.5 157.9 35.7 -18.0
                       Nahuel 1   71.8W 156.8 160.3 36.3 -16.4
                      DirecTV 1   72.5W 157.8 161.2 36.5 -15.7
                          AMC 6   72.0W 157.1 160.5 36.4 -16.2
                          SBS 6   74.0W 159.8 163.2 37.0 -14.3
                     Echostar 4   77.0W 163.8 167.3 37.7 -11.5
                          AMC 5   79.0W 166.6 170.1 38.1  -9.5
                      Nimiq 2/3   82.0W 170.8 174.3 38.6  -6.6
                          AMC-9   83.0W 172.2 175.7 38.7  -5.5
                   Brasilsat B3   84.0W 173.7 177.1 38.8  -4.5
                          AMC 2   85.0W 175.1 178.5 38.9  -3.5
                          AMC 3   87.0W 177.9 181.4 39.0  -1.5
                           IA-8   89.0W 180.8 184.3 39.0   0.6
                      Galaxy 11   91.0W 183.7 187.1 38.9   2.6
                     Nimiq 1/4i   91.0W 183.7 187.1 38.9   2.6
                   Brasilsat B4   92.0W 185.1 188.6 38.8   3.7
                      Telstar 6   93.0W 186.5 190.0 38.8   4.7
                      Galaxy 3C   95.0W 189.4 192.8 38.6   6.7
                      Telstar 5   97.0W 192.2 195.6 38.3   8.7
                      Galaxy 4R   99.0W 195.0 198.4 37.9  10.7
                     Spaceway 2   99.2W 195.2 198.7 37.8  10.8
                DirecTV 1R/4S/8  101.0W 197.7 201.2 37.4  12.6
                          AMC 4  101.0W 197.7 201.2 37.4  12.6
                     Spaceway 1  103.0W 200.4 203.9 36.9  14.5
                          AMC 1  103.0W 200.4 203.9 36.9  14.5
                         AMC 15  105.0W 203.1 206.5 36.3  16.3
                      Anik F1/R  107.3W 206.1 209.5 35.6  18.4
                      DirecTV 5  109.5W 208.9 212.3 34.8  20.2
                EchoStar 6/8/10  110.0W 209.5 213.0 34.6  20.7
                        Anik F2  111.1W 210.9 214.3 34.2  21.6
                  Solidaridad 2  113.0W 213.2 216.7 33.4  23.1
                       SatMex 5  116.8W 217.7 221.2 31.7  26.0
                     DirecTV 7s  119.0W 220.2 223.7 30.6  27.5
                     EchoStar 7  119.0W 220.2 223.7 30.6  27.5
          EchoStar 9/Telstar 13  121.0W 222.5 225.9 29.6  28.9
                     Galaxy 10R  123.0W 224.6 228.1 28.5  30.2
                      Galaxy 14  125.0W 226.7 230.2 27.4  31.4
                  Galaxy 13/H 1  127.0W 228.8 232.2 26.2  32.6
 Intelsat Americas 7/Echostar 5  129.0W 230.8 234.3 25.1  33.7
                         AMC 11  131.0W 232.8 236.2 23.9  34.8
                   Galaxy 1R/15  133.0W 234.7 238.1 22.6  35.7
                         AMC 10  135.0W 236.5 240.0 21.4  36.7
                          AMC 7  137.0W 238.4 241.8 20.1  37.6
                          AMC 8  139.0W 240.1 243.6 18.8  38.4
                   EchoStar 1/2  148.0W 247.7 251.1 12.8  41.5
       Satellite Finder is (c) Copyright 2004, P. Lutus
Code:
                      Appleton, WI 54914
PSB, Thank you for your replied and your helped. So you said that for my true sout is IA 8? So this mean I will need to aim my dish at this satellite as a reference point for my motor dish to start it? So does this mean that once I get some quality signal from this IA 8 satellite, I can use my motor dish and it will automatic find the other satellite signal when I program them into my receiver? Is there any other easier instruction step by step on how to set this up somewhere online that I can use? I tried to understand the menu that came with the motor equipment but I can not understand it that well. Any help and tips are greatly appreciate. Thank you for your help.
Yes you need to set up on IA-8
After setting them up all the other satellites will then be available, use USALS if you can but some satellites to the far east and west of your arc will have to be set up with DiSEqC 1.2
Thanky you PSB for all your help...
I tried to setup my motor dish but however, i ran into another problem. I don't have IA 8 program into my Pasat 2700a receiver. What do I do now? I have satellite G11 in the recevier which is 91 w. If I use this one should it work as my ture south Satellite too? Please help... thank you.
Any satellite close to the top of your arc will work when setting up a motor (use USALS)
There used to be a satellite (Telstar 4 at 89º degrees) at the same position, if that is listed on your receiver you could use that!
Will an SG2100 work with a 31" Alphastar Dish?
