I have searched and really cant find any information on what double play is exactly. I understand there is no keyword for it but, how do I use it? And what does it do?
Thanks in advance....
I believe it is the dual-live buffer feature; press the down arrow button on remote while watching a channel you want to watch. Tune again to another channel you like to watch and use the down arrow to toggle between the two buffered channels. Pause and trick play with remote is available for both channels so you can pause one while watching the other. Used to work with the yellow button but now it's the down arrow. Only for DVR with CE s/w and active for two hours but limited to buffer time which I think is 90 minutes. Hope that is accurate and helpful. If you have a dvr with CE try it.
Thanks for the info!
Has anyone run into an error message with MRV that says to many items are being played from the playlist. I had content playing on my computer from the bedroom DVR and I was getting this message when I would try and play content on the family room dvr from content on the bedroom DVR at the same time.
I do like the combined playlist but I wish you could shade the title to a degree so you could instantly tell which dvr the content resides on.
Alos why do we have to engage DLB, just have it one at all times
Just my 2 Cents
Love the MRV function but it is a bit choppy running it through a 14MB powerline
Trevor
Limited time offer
