newbie needs help | SatelliteGuys.US
newbie needs help
jeff4242
20
i got a 90cm geosatpro with the geosatpro ul1-bullet universal lnbf and can not hit anything just wanna know does it matter that i have a cw700s and that the dish is almost on the ground ,,,, i am trying to get 123 10r i have no motor yet,, i wanna know about the lnb do you start with the rg6 cable at the buttom and turn it 43.9 clock wise
True Azimuth: 237.14 now what one do i use
Magn. Azimuth: 243.41 or this one
North Latitude: 34.4158
West Longitude: 81.8106
First of all welcome to the Satellite Guys! Be sure to read all the stickies on site rules in the FTA section first! :welcome
Let me take a stab at your problem
Make sure that your STB box has the right settings for your LNB, any switches make sure you have the number correct for the LNB that is seeing the bird you want!
Go to the list here on this site for your angles.
Punch in your zipper code on the Satellite angle calculator on the list site, that will get you where you need to point!
Make sure you use the right one for your setup, stationary or motor! There is a difference!
Magnetic AZ is what you want. Since your a stationary setup see this site for help! Scroll down to statonary installation, follow the directions to a tee using the information from THE LIST on your location!
Set your skew to angle number shown on THE LIST for what satellite your trying to get.
More replys will soon follow if futher help is needed so check back here often today!
Most inportant, make sure you have a clear LOS (line of site) without any tree growth, buildings in the path of the satellite you want to get!
This should get you in the right direction.
Facing the dish - turn the LNB 44° counter-clockwise. I have attached a screen capture from GeoSatFinder.com as a PDF, hope this helps.
Bob
Thanks everyone i hit 123 w and got some weak channels but i will just do some fine tuning
but thanks again to everyone
Instruction download requested
New to FTA.
