newbie needs help | SatelliteGuys.US
newbie needs help
chum1976
SatelliteGuys Guru
127
11
pa
Hi,
A purchased a c-band dish system for a few bucks and installed it. The only problem is when I go to set the limits I get a message saying jack error no return pulse. The receiver is a general instrument i350. I think the wires on the back are correct, but I have no book. There are 5 wires grouped together(large red and white),orange,green,brown. An there are a smaller red and white and 2 round cable wires. Any suggestions would be helpful. The owner dident use the dish for a year and it worked then so maybe the motor is bad? I ditched cable for OTA and would like to tinker in FTA.
Thanks!
Welcome to the group :) there is a manual for the 350 in the manual section
usual configurations are like this
wires big red & white wire are M1 & M2
that should leave 3 other wires from same cable ( orange,green & brown)
brown = ground , orange = +5 & green = top hat symbol
Small group of wires = feedhorn ( usually Small black , small white & small red wires)
black is ground , white is pulse , red = +5 volts
before connecting or moving any wires look at the manual and see if your motor type is lysted for a more accurate detailed listing. page 41
Hi,
Thanks for the info. The wiring is ok, but getting jack error no return pulse. There is a local guy here that works on them so I will keep my fingers crossed.
check wire connections ( for the sensor ) the three orange green and brown and make sure they are good ... thats the easiest check. if you have a meter check if has continuity.
its been a while but ones i used in the past only used two for the three wires. but it varies with motors/ actuators
Commercial Satellite Installer
BVOC Members...look inside....
