Newbie question | SatelliteGuys.US
Newbie question
sreraku
4
I have just bought a super dish which receives 105,110,119 signals by oversight. I wanted to buy a superdish which receives 110,119,121 for international programming. What should I do to receive 110,119,121 instead of 105,110,119 signals? Please help me.
you can use the same dish but will need to buy the lnb set and holder that works with 121. Also, keep in mind that not only is there a 105/110/119 and a 121/110/119 but there is two different types. They make a type one and a type two. Channel master makes the one that uses the fiberglass reflector and the other type of superdish uses a metal reflector. Last time I looked they were selling them one ebay. I'm not positive but i think the channel master one is called the Type2 dish and the metal one is called the type1 dish.
Thanks Brett for the answer. I am happy that I can get rid of 105,110,119 LNB and just replace it with 110,119 & 121 LNB set to receive international. Can you tell me which 121 LNB (type1 or type2)should be used to get south asian or international channels please? Thanks in advance
which LNB to use
Dish 1000 install times
