Newbie Question | SatelliteGuys.US
Newbie Question
JD06
4
Hi,
I have a RCA Scenium d52w136d and a H10-250 hd tivo. I can only get 420p and 1080i signals the other 2 have a blank screen. I have a couple of questions about this.
1. Why am I only getting these signals?
2. Does anyone know the native resolution of my tv? I can't find it anywhere.
3. Is 1080i a better signal than 720p?
Thanks.
According to your manual (attached) on page 2 (page 4 in the pdf file), your TV can only use 480p or 1080i through the DVI port. I am going to go out on a limb here, and suggest you are using the DVI port which has this limitation.
As for whether 1080i or 720p is better, that is a matter of opinion.
Ted
Good Install Experience
Why does D* charge to lease a receiver
