Newbie - VIP622 has complete signal loss, 3 others in house all fine? DIRT? | SatelliteGuys.US
mercurymike
2
The 622 was working fine one day last week, next day nothing! (about 2 years old)
Run Check-switch countless times. Double checked all coax connection points and powered down both box and power insert also. Two other 622s perfect, also a 500 series work fine.
No signal is showing on test switch screen. PVR previously recorded programs are viewable fine for what was recorded before last week. I don't use OTA antenna, all feed is dish.
Nothing blocking dish on roof.
HELP????
Home Protection Plan coming up if you don't already have it. Then a call to tech support to swap out the 622, of course you already knew this before posting?
Thanks, I do have protection plan. I've been with dish over 16 years and every time I had a issue it's always been a complete failure of the box or Disk crash. Never anything like this. I already set up & cancelled tech visit last Fri as I'm not sure I'll keep Dish if AMC is gone for good.
learning the remote colored buttons
Would you like to see Dish drop The Weather Channel?
