Newest DirecTV dish& LNB - kaku 99 101 103 LNB types | SatelliteGuys.US
TELE Frontier
18
Flat Panel Antenna
Hello,
It seems that two different type of horns in the above Kaku SWM LNB exist now.
Are those SWM LNB used in one same dish(99 101 103)?
Thanks in advance,
yes
There are 2 types of LNB's for them. a SWM setup which only has one output and one with 4 outputs. The 4 outputs go into 4 receivers or a 6x8 multiswitch.
The 5 LNB setup works the same too
Directv has different manufactures that make the LNBs, and have slight variations in design. All the SWM 3LNB setups receive 99/101/103. Cap colors vary clear and white, but there are also slight differences between manufactures but they all work the same.
Thanks for your information.
Except Cap., Zinwell and Eagle aspen and WNC are from taiwan manufacturer assembling in china.
For Cap SWM LNB, I assume that it is also made in china. Do u know the website of Cap.?
72.5 Local Markets moving to 99 / 103
Caller ID Stopped Working
