Nielsen changed local channel area - get my local channels back? | SatelliteGuys.US
tri-tom
Southeast Ohio
First, apologies for being new to the forum, but this place seems to be the best place to find an answer. Yes? I hope so.
I moved to Athens, OH (SE Ohio) two years ago. Local channels (TWC) were Columbus, OH which is where I moved from - great!
Jan. 1, 2012 I woke up to find that the local channels were Charleston, WV and Huntington, WV. No warning, but I am sure everyone has heard those stories...
TWC was "great" at first and added some (non-HD) channels from Columbus which gave us our news, although not the one we wanted.
Recently, I had to move to DirecTV (because of TWC incompetence) and of course the same local channels of WV. No ranting against the WV channels, but my kids all live in the Columbus area, and we would like to continue getting them.
Any hope? Again, I am a newbie at Satellite (although I do have some technical savvy).
Cheers!
Tom
Some on the site say that you can "move" as in change the physical address to one in Columbus or that DMA but that is not supposed to be allowed.
"Moving" is easy to do, especially if you have an in-DMA address to use, which it sounds like you do.
Another option is an over-the-air antenna and Directv AM21. The AM21 is an add-on module to your receiver that will allow you to watch and DVR OTA stations, which become integrated into your guide. However, just using the downtown Athens coordinates, Columbus looks difficult to receive, but that could vary significantly depending on your exact address, elevation, antenna quality, and antenna height.
Do a search and read threads on "moving". Essentially you are changing your service address with Directv which will change your locals. If they change just the mailing address it will not help with locals, service address has to be changed by CSR, not website.
:welcome to Satelliteguys Tom!
As others have noted, "moving" isn't difficult, and it technically allowed by Directv, many do it without any issues.
Direct tv tivo dvrhd34 Record ?
Genie to Go-Nomad-your thoughts?
