No Audio DSR605 HDMI Output | SatelliteGuys.US
Bob5519
19
Ohio
Have no audio on the DSR605 on the HDMI output while tuning the signal. Tried another HDMI cable and still no audio. There is audio, the steady tone, when using the analog outputs. Have a green bar and have not activated the receiver.
The HDMI audio of the TV does work with a different brand satellite receiver. Is this normal for a Shaw receiver or is the HDMI defective?
Just found out this is a known issue with Sony Bravia TVs. No audio on two TVs. One TV has an HDMI with analog audio on the same input. May be able to use that. The second input is HDMI only.
The TV input with both HDMI and analog audio gets only video when both HDMI and analog adudio cables are connected to the same input. Has audio when only the analog audio cables are connected. So something is stopping the audio when bothe the HDMI and analog audio cables are connected.
Did not have this problem with another brand satellite receiver.
