No Audio from 722 | SatelliteGuys.US
No Audio from 722
dmendenjr
1,499
The keystone state
Worked fine last night, when I woke up this morning - no sound. Not from any of my programs on the DVR or live shows. I still get it from other inputs, though. Any suggestions? I only had this thing about a week, so if you recommend something exotic, I might need it explained how... Thanks
Well, after finding a referance in another thread to "reset"ing. I finally found the power/reset button hidden away. That seemed to do the trick. Thanks anyway
Weird Problem
1000.2 Cable Routing Question
