No program signal | SatelliteGuys.US
No program signal
Landon
39
I have the dish 322 system and not receiving tv programs on the secondary receiver. I have tried another good tv at the secondary site and still nothing. I can get menus and all the other items but not tv programs. My primary tv work fine with no problems. This problem came about as I was changing channels. Does this sound like a receiver gone bad?
Thanks for any info.
Yes that fixed it.
Man, that was quick.
Thanks a lot.
What causes this to happen?
Man, that was quick!! Thanks a lot.
Yes that fixed the problem. Now tell me what happened.
The rcvr's software will freeze up from time to time.
Think of it like a computer, you have to reboot your computer every so often.
The best way to prevent it is to turn the power off when you are not using it.
Glad I could help.
Dumb Teenager fried #2 Remote????
VIP222 update L.303
