no reception canal algerie and abc casper | SatelliteGuys.US
antenna
18
Hello, is anyone receiving canal algerie ai5 11874h 22.000 and abc casper 12104v 2.583 galaxy 10r???? I don't get nothing from those two stations all day.... thanks
Try using TP 12104 V SR 2222
Try using
G10R
TP 12104
V
SR 2222
scans in as SNG for me....
For Canal Algerie
I am receiveing with what you have posted
T-5
TP 11874
H
SR 22000
Thanks Larry
Thanks Larry sr 2222 worked just fine...lyngsat wasn't up to date...Thanks
I am not understanding something about the settings that people give out.
Doesn't the receiver do a power scan, or blind search and produce all that would be possible from the bird, or birds that you have a good quality signal on? Is it possible to miss something if the manual changes to frequency are not made? Joe
Some receivers do not do a blind scan. You have to enter the transponder numbers and signal rate numbers as well as the PID numbers separately. Blind Scan makes playtime so much easier.
Yes, it's very possible. For various reasons.
Al
pansat2500a (again)
no audio on pbs
