"no Satellite Signal" | SatelliteGuys.US
NOHDjunkie
417
Lacombe La
My 622 goes into error 002 "No Satellite Signal" after about 3 minutes.
Click the guide button and the channel pops back on. three minutes later it does it again. Change channel and three minutes later back to "no Satellite Signal".
Happens on 110, 119 and 61.5
My 942 is fine.
Dish 500, for 110 and 119. wing dish for 61.5 and a Dpp 44.
Rebooted to no avail.
Suggestions?
Thanks.
Unhook the coax from the dish do a check switch. This will take a few mins because of no signal....this will clear the switch matrix. After it is done and has a bunch of x's and says no switch detected. Hook the coax back up and run a check again. Cancel back to tv once it returns to your program, see if this fixes the problem since it is only on that receiver. If that don't work try a different port on the DPP44.
Receiver Problems Help!!!!
Raleigh HD Locals
