No Serach Punctuation?! | SatelliteGuys.US
jayiw
327
84
Is it me or is there no way to use punctuation in Search? I was trying to search for the new X-Men movie and there is no way to use the -. If I do X MEN no results. I had to use just X and browse the results. Numbers are there but no punctuation that I can see.
Jay
Use the remote numbers for your keyword entry- 1 will give you ['-.&1], * is Backspace, and 0 is [0(space)]. 2-9 function just like your phone for texting (ie 2 will give you [ABC2abc])
YES! Thanks! :)
Can't Get Past "Download Software" step of Receiver install
Ethernet connection
