no signal after storm | SatelliteGuys.US
ntaylor44
2
I have a 3LNB dish with 4 receivers. I think they are DRD435. No signal on all any transponder on any satellite after strom the other day. Checked dish alignment looks ok. Guessing LNB is bad. Picking new one up tonight to try.
Only other thing that I am not sure of is, checking power at the LNB I only have voltage coming from one receiver. Is that normal that only one powers the LNB? Or should I have voltage coming from each receiver?
So if my receivers are powered up and they aren't putting out any power, they are probably damaged as well?
I checked two of them right at the back of the receiver and had no power.
Having trouble with my 5LNB Slimline install
AM21 slowing you down?
