charper1 said:So with only one receiver, do you only have the one standard 18" dish, and does that have a single or dual output LNB?
Have you tried it without that surge protector?
Do you have access to another receiver to test; maybe a friend?
JHAT76 said:Plugged box into upstairs outlet.......problem solved. Now I can just get over having that big extension cord running through my house, then no problem.![]()
Someone I work with said it might need to replace the circuit in the box
Any other remedies?
JHAT76 said:Plugged box into upstairs outlet.......problem solved. Now I can just get over having that big extension cord running through my house, then no problem.QUOTE]
Have you got a GFI outlet on the same circuit? If so it could be wired wrong. Think back, about the time the problem started did you do any electrical work in the home? Or add a major appliance (for enstance a couple of years ago I installed a new over the range microwave and plugged it up to the same circuit as a window AC, everytime I turn on the microwave while the AC is on it trips the circuit)? Always try to put major appliances on their own circuits.
Limited time offer
